Home › Forums › Products › Rackmount › Emote: Inter-Connecting FX Chains › Reply To: Emote: Inter-Connecting FX Chains
For the mono insert approach do you mean having FX Chain 1 handle the left channel and FX Chain 2 handle the right channel? I unfortunately don’t have extra chains to spare so that won’t work for me.
I checked the documentation for my reverbs and they do say stereo in/out except for DesertPercussion1 which says “Summed in, quad out” so presumably that means I can’t use that algorithm with a stereo signal. I should have clarified it’s less about how many inputs/outputs it has and more about whether it can support a stereo input and output.
Some effects are able to convert mono inputs into stereo outputs. Are these flexible enough to take a stereo input instead? That would be the most useful if it could accept either mono or stereo in and then always output stereo.
