Home Forums Products Rackmount H9000 and Pro tools HDX Card. Question and setup Reply To: H9000 and Pro tools HDX Card. Question and setup
#185552
    Yes, you can use analog and AES simultaneously.
    You can use any combination of analog, USB, digital, and expansion cards simultaneously. The only limitation is that you must choose one type of digital audio protocol (AES XLR, AES DSUB, ADAT, SP/DIF etc.) This should be clear when you set your “Digital Audio Mode” in the system settings; you can only make one choice.
    I’ve asked you to please email support@eventideaudio.com with a screen recording that demonstrate the metering issue you mentioned. Thanks.
