Home Forums Products Rackmount H9000 and Pro tools HDX Card. Question and setup Reply To: H9000 and Pro tools HDX Card. Question and setup
#185578
GoldenRaven
    So I did 8 stereo inserts with EFFX Chains (Pro Tools 1-16)
    I have left  Pro Tools  17-24
    I was trying to do Hardware inserts via H9000 Analog I/Os    but all the ways I tried did not succed
    Can you show me  the ways I can do best Hardware Insert in Pro Tools?
    I was able to do AES Inserts, but  analog Hardware inserts I did not succeed.
    I will attempt to also use the AES (the output) going to a DAC to have 80 Ch of playback, but I am waiting for my Tascam DB25
    can you also share the best ways to do that?
    Also can you explain to me the most popular ways to use Direct I/Os?
    and to have clear, any routing or any I/O configutarion and simultaneous I/Os  should fit with the maxium i/Os of Pro Tools I/O(with Pro Tools DAW)?
    Thanks so much for your awesome help!
