Home Forums Products Rackmount H9000 and Pro tools HDX Card. Question and setup Reply To: H9000 and Pro tools HDX Card. Question and setup
#185596
    Sorry, I don’t understand what you mean by EEFX.
    The H9000 uses FX Chains, and each FX Chain has up to 4 algorithm (effect) blocks.
    Once you have audio passing through an FX Chain, you need to load an algorithm (example Blackhole) and now your audio will be processed by Blackhole.
    Setting up analog I/O on the H9000 is a very different process from setting up the PTHD expansion card.
    You need to connect your signal to the H9000’s analog inputs/outputs (XLR or DSUB) and then you need to configure the FX Chain to use analog I/O.
    I would recommend that you work on getting your 32 channels of audio using the PTHD card figured out first before you attempt any other I/O setup.
