Home › Forums › Products › Rackmount › H9000 and Pro tools HDX Card. Question and setup › Reply To: H9000 and Pro tools HDX Card. Question and setup
Sorry, you understood me wrong.
I already pass audio from Pro tools within FX Chains, I am using all Pro Tools I/0s on C (channels 1-16) ..is working fine.
Then I have D free in Pro Tools I/O, D is where I want to use the Analog I/O of the H9000 to use them as analog Hardware Inserts for my gear and I want the other 8 channels in D to use the H9000 AES Dsub to go to a DAC from 8 channels of Playback
then I want to see how I can use the stereo XLR Analog in to listen to how the h9000 converters sound and route that signal to the XLR AES/EBU Out, to print mixes
Here you can see the FX Chain 4 that goes up to ch16, meaning that D in Pro Tools I/O is empty, not used yet
Please, can you help me with how to make analog Inserts in the H9000?
Thanks
