Home › Forums › Products › Stompboxes › H90 Pedal Boards › Reply To: H90 Pedal Boards
3M Dual Lock (don’t buy or use the low ply version, get the big boy version). Here’s my stance and rationalon pedal board mounting (if mounting to metal boards):
1. Only 3M Dual Lock
2. It’s strong as hell
3. It CAN be a pain to peel pedals off it so
4. Minimize that by cutting 4 roughly 1″x1″ squares for each corner rather than one long strip (you’ll struggle to get it off the board again that way)
5. When you need to, you can use Pliers to pull up the Dual Lock from the board itself – when it comes off it leaves no residue
6. It’s cleaner than velcro, doesn’t get anywhere near as much schmootz stuck in it, and is stronger than velco – best stuff for a pedal board
7. It’s a little pricy but 100% worth it
8. Buy it in black.
