Home Forums Products Plug-Ins Blackhole renamed in Logic 10.8? Reply To: Blackhole renamed in Logic 10.8?
#185787
tlongabaugh
    Unfortunately, Apple never fully reverted the changes made in Logic Pro 10.8 and Logic Pro 10.8.1.
    This is the stated behavior as of Logic Pro 10.8.1 (from the Logic Pro engineering team): If there is an Audio Unit that is available as effect and midi controlled effect, the midi controlled effect is hidden from the plug-in menu. It still is available for existing projects, though.
    So, existing sessions will reload correctly, but only Blackhole (No MIDI) will be available in the insert menus. Apple does not seem willing to change this behavior, so Blackhole will not appear in insert menus.
    The only difference between Blackhole (No MIDI) and Blackhole is the lack of MIDI control in Blackhole (No MIDI). When used as a standard insert, Blackhole (No MIDI) will provide the same sound and experience as the Blackhole plug-in did in versions 10.7.9 and prior.
    What issue are you running into that you hope to have resolved?
