Home › Forums › Products › Rackmount › H7600 Two amp set up › Reply To: H7600 Two amp set up
#186321
    For full stereo processing you will want to use both inputs and outputs 1 and 2 on the H7600. You can use the 1/4 inputs, and XLR > 1/4 cables for the outputs (whatever you send this signal to should accept line levels).
