Home › Forums › Products › Stompboxes › H90 recall a tweaked Preset? › Reply To: H90 recall a tweaked Preset?
November 27, 2024 at 12:33 pm
#186523
Another workaround that will work in some cases, set up the expression pedal so that your default preset settings are the lowest value that your expression pedal can go to. So when you are in full heal down, you will have the default patch settings.
