Home Forums Products Stompboxes H90 latency Program Change Reply To: H90 latency Program Change
#187062
apalazzolo
    If you get out of bank mode, you can easily set up a hotswitch with your alternate aggravate and reverb parameters.  That will allow you to switch between the two properly.
    If you need to stay in bank mode for some reason, you can accomplish the same thing described above using an external aux switch.
    Good luck!
