Home › Forums › Products › Stompboxes › Problem installing firmware h90 › Reply To: Problem installing firmware h90
#187231
mattpreacherz
    Hello. What do you use to make this ?
    Here my solution to this after a lot of research :
    Use Recovery Mode:https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/appendix/startup.html#recovery-mode
    Make sure you are not using a USB hub.
    Make sure there are no other USB or MIDI devices attached to your computer.
    Try a different USB cable
    Try a different USB port.
    try an USB-C to USB-C cable
    Make sure no other programs are running.
    Make sure antivirus or firewall programs are not interfering with the update.
    10. Try a different computer, or device.
    For information, I never can do the last update from my MacMini. And it’s simply works at the first try in an old Surface Pro, with an USB-C to USB-C cable 🙂
