Home › Forums › Products › Stompboxes › H90 Inserts – I’m Using [Fill In The Blanks] › Reply To: H90 Inserts – I’m Using [Fill In The Blanks]
January 27, 2025 at 6:01 am
#187917
I have similar issue to one of the guys above…
Set up as follows…
Kill dry is on
EVH style Detune is on in parallel with my dry signal using GigRig Wetter box and mixed down to same volume level as amp dry.
BUT
I want to use 2 x seperate delay’s in the inserts and set to Parallel
These delays are both set to KILL DRY…
BUT when selecting “parallel” routing of the Inserts on the H90 (irrespective of whether the delays are on or off) – my volume DOUBLES???
grrrr why…..
Surely it shouldn’t allow signal through as parallel – should only be the delayed sound and kill dry???
Please help
