Home Forums Products Stompboxes H90 Routing Questions Reply To: H90 Routing Questions
#187998
Try turning Kill Dry off for the Program, and then using the Program Mix to blend in the wet amount for the Delay>Reverb.
This way, you should be able to dial in your individual delay and reverb amounts, and then dial in the overall mix of the dry/wet signal with the Program mix.
