Home Forums Products Rackmount Emote not connecting to H9000R Reply To: Emote not connecting to H9000R
#188164
ONEMUSICSTUDIO
    Hello,  just got a H9000R and emote does not find it via Ethernet cable.  I have a mac Studio M1.  I used cat5, cat 8, either worked.  I checked my network and it shows a “Self assigned IP” with a yellow dot.  I tried using the + sign in emote to to manually added, i sued the Ip in my network, it made the H9000 appear in the upper left part of emote, I clicked on “automatic Connect’ and showed an error msg (See Attached picture).
    I believe this H9000R is an amazing unit, but if cannot connect it’s just disappointing.
    Please, can someone help me to fix this issue?
