Home › Forums › Products › Rackmount › H9000 / Emote – confirming features don’t exist? › Reply To: H9000 / Emote – confirming features don’t exist?
Update: it would seem the Ableton (12) LFO is the factor in causing the crashes. Using other M4L lfos seems to be working much better – I did have one crash, but not sure if modulation was the cause.
anywho-
RE: Random
i would like to be able to randomize in emote as opposed to the front panel. I don’t see any options to do this in emote? if you can trigger the randomization with cv/midi, that would be really cool.
What would be really cool with emote is randomize all parameters function, randomize group parameter function, and a randomize per knob function. The best example I’ve seen of this is the aura editors. You can lock groups preventing randomization for parameters too.
as far as random % –
this would allow for decreasing the random range. Ex: if random was set to 10%, randomizing a parameter page would only randomize the current position within 10% of the range. Like a wiggle of the knob as opposed to it jumping dramatically.
