Home Forums Products Rackmount DSP4000 Problem In Internal Ram Reply To: DSP4000 Problem In Internal Ram
#188387
noodle1
    I believe this is caused by simply an intermittent error, or a bad battery backed memory chip, or hardware fault. My understanding is you can do a re-init to clear the error (hold 8 at startup) and see if that helps or next replace the battery-backed memory (should be in socket). Try to match the P/N, it should be something like BQ4013YMA-120.
