Home Forums Products Rackmount 2 computers controlling H9000 via Emote? Reply To: 2 computers controlling H9000 via Emote?
#188576
bsfreq
    I’ve been using Emote to control the H9000 on two computers simultaneously. No problems there. I’ve also had two Emote instances open on the same computer. One inside a DAW as a plugin, and the other one as standalone. This worked fine as well.
    Emote still crashes each time if I start Emote before the H9000 has fully booted up. After that it works fine. (perhaps this will be fixed one day along with other updates)
    Also, I recommend using a wired ethernet connection, at least for connecting the H9000 to your wifi router, even if your computers are connected via wifi. The included wifi dongle, while nice to have, is limited in its range and performance. Afterall, it’s just a dongle..
