Home › Forums › Products › Stompboxes › H90 Expression Calibration seems a off › Reply To: H90 Expression Calibration seems a off
#188909
joecozzi
    First, I’d like to map the pitch on an octaver to raise an octave when I hit the external footswitch (in exp 1). Something strange keeps happening when I choose the amount on the pedal though – no matter what pitch I set the external switch to change the pitch to, it will always go to another pitch. And it isn’t just one off every time – sometimes it’s a few semitones, sometimes it’s 1… and the full range of the parameter will be right on. I am using a TRS cable and have tried with two different foot switch devices to confirm the issue is not with the footswitch.
    I’m having a similar experience. Let me discuss with developers and get back to you. For the time being, the way around this is mapping your aux switch to one of the three available HotSwitches. Program that HotSwitch to go between the values you need. That works for me. Directly mapping the aux to the parameter causes the issue you’ve raised.
    Secondly, I’m trying to use my expression pedal (in exp 2) to control the speed of the loop to sweep to a fourth up (around 100-136). However, I don’t seem to be able to select expression 2 to control that parameter – only expression 1 shows up. I have tried calibrating but it doesn’t seem to fix either issue – it also just says “off” after I complete it. Is there something I’m doing wrong here? Any help would be greatly appreciated, thanks so much!
    When you map the expression pedal to the Play Speed parameter on the Parameter Mapping page, can you turn quick knob #3 to show you Pedal #2? It does seem to take one whole turn of the knob to register.
