Home Forums Products Stompboxes Factor Pedals and Synths Reply To: Factor Pedals and Synths
#189435
    Yes, the input/output levels of all the stomp boxes should be set to line. Is that how you have it configured?
    Your synths are connected directly to the ModFactor input? Your mix settings and which algorithms you are using on each Factor pedal can increase the gain before it reaches the Space.
