Factor Pedals and Synths
Home › Forums › Products › Stompboxes › Factor Pedals and Synths
    • #189432
      mikengstrom
        HI,
        I have all 4 factor pedals for use with my synthesizers.
        I’m running them in series Modfactor>Pitchfactor>TimeFactor>Space > audio interface.
        I’m just wondering what the best input/output level switch selection should be. I would assume having them all on line level but the signal coming out the end of the chain seems to be really hot. It will drive the input on the space to peak especially if have the others enganged.
        Cheers
      • #189435
          Yes, the input/output levels of all the stomp boxes should be set to line. Is that how you have it configured?
          Your synths are connected directly to the ModFactor input? Your mix settings and which algorithms you are using on each Factor pedal can increase the gain before it reaches the Space.
        • #189458
          mikengstrom
            hi,
            Yes I’m running synth output direct into the modfactor mono in.
            cheers
