Home › Forums › Products › Stompboxes › Expression pedals for H9 › Reply To: Expression pedals for H9
April 5, 2025 at 3:18 pm
#189452
I have two Zoom FP02’s which I use – but exprience strange behaviour.
When I just connected with TRS, the value range was 0-90, and depended whether I pressed the plug all the way in on my H9 or the ExpPedal, I got the max value when heel down.
So I experimented, and came to the solution of making new chords, using TRS plugs. I solder ground/tip on the H9 side, and ring/ground on pedal side.
This works – BUT – some of the presets show me 0-100, but many presets only give me 0-90…?
Is there a good reason for this? – And is there a way to manually calibrate?
