Home Forums Products Stompboxes H90 Tail Query Reply To: H90 Tail Query
#189653
    Can you be more specific with what you’re looking for?
    If you have bypass tails OFF, then you can bypass the delay/reverb preset and that will immediately cut off the tails.
    Otherwise, you would need to adjust the feedback parameter to stop the tails from ringing out.
    You could try using a HotSwitch if you need an easy way to dial back the feedback amount.
