H90 Tail Query
Home › Forums › Products › Stompboxes › H90 Tail Query
    • #189643
      ChillyC
        H90 synth user here.
        Great unit but generally, is there any way to cancel a patch’s feedback trail, i.e. other than by sweeping the respective feedback dial back to zero? Thanks in advance.
      • #189653
          Can you be more specific with what you’re looking for?
          If you have bypass tails OFF, then you can bypass the delay/reverb preset and that will immediately cut off the tails.
          Otherwise, you would need to adjust the feedback parameter to stop the tails from ringing out.
          You could try using a HotSwitch if you need an easy way to dial back the feedback amount.
        • #189671
          ChillyC
            Thanks, hadnt thought of a hotswitch…will give this a try.
