Home › Forums › Products › Rackmount › digital ins / outs › Reply To: digital ins / outs
#189977
    There aren’t any special configurations to get ADAT working, you just need to have the clocking set correct (either have the other devices sync to the H9000, or vice versa) and note that the sample rate will max out at 48k.
    A few options I can think of:
    • You can connect your eurorack or kyma via ADAT to the existing setup. You would just have to choose whether you want to use the devices on the ADAT chain OR the AES chain. It’s very easy to make some Session presets on the H9k to load up either your AES or ADAT configurations, you would just need to be ok with the either/or scenario.
    • You could get a 1/4 patch bay and connect all of the gear from the current AES chain to the patch bay. You can then always use ADAT instead of the AES, and it would be a bit more flexible than the first option suggested since you can patch in whatever you need on the 8 analog channels depending on what you are working on.
    Let me know if you’d like any further information.
