Home › Forums › Products › Stompboxes › Can you turn root note off in Vocaltune H90 › Reply To: Can you turn root note off in Vocaltune H90
#189990
    I don’t see where the Root note will matter in a Chromatic scale.  Even if you change it with the momentary Root Learn switch, VocalTune will still correct to the nearest of 12 notes.
    So, yes.  You can still customize all the other parameters to taste, while ignoring the Root note (in Chromatic).  It’s easier to hear & adjust with the Program Mix temporarily at 100%.  Great for doubling at 50%.
