Can you turn root note off in Vocaltune H90
Home › Forums › Products › Stompboxes › Can you turn root note off in Vocaltune H90
    • #189989
      xdannyx
        Just curious to see if there is a way to turn off the root note in the new vocaltune algorithm and still have everything else on, in this case would set the scale to chromatic to just get very slight correct but still get to use all the other parameters in the algorithm
      • #189990
          I don’t see where the Root note will matter in a Chromatic scale.  Even if you change it with the momentary Root Learn switch, VocalTune will still correct to the nearest of 12 notes.
          So, yes.  You can still customize all the other parameters to taste, while ignoring the Root note (in Chromatic).  It’s easier to hear & adjust with the Program Mix temporarily at 100%.  Great for doubling at 50%.
        • #190037
          xdannyx
            Thank you!
