Home Forums Products Stompboxes Knifedrop AUX Switch Capabilities? Reply To: Knifedrop AUX Switch Capabilities?
#189997
    Sorry for the issues you are having. You should use the “OXU” setting as mentioned in the comment above.
    With that setting, the left footswitch should decrement the preset, and the right footswitch should increment the preset. If that is not working, what is happening when you press the footswitches?
