Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#189999
d.talma
    I posted this as a separate thread, but I think it should be in this one…
    Simple feature, difficult to explain:
    Each patch has the option to assign the 3 internal foot switches to parameters twice. And since the H90 only has three physical foot switches, you can toggle with the perform knop between the first 3 assignments foot switches, and the second 3 assignments. That works great!
    In my case I often have:
    primary: P: tap, A: bypass A, B: bypass B.
    secondary: P: HS1, A: HS2, B: HS3.
    Currently the LCD displays the status of the three foot switches that you have selected. And that is double information:
    The LED’s already show you if a foot switch is ‘on’ or ‘off’. And then in the display it says ‘bypass/active’ or ‘HS1 Off/On’.
    I would rather see that the display shows the status of the three foot switches which currently aren’t selected. In that case I can see from the three LED’s the status of the three active foot switches, and the status of the other three in the display.
    This is especially handy if you have assigned these to external switches, like I have. The external switches do not display the current status, and in this way I would be able to see the status of all six switches on the fly.
    Daniel
