Home Forums Products Rackmount Algorithm Load Mutes FX Chain Reply To: Algorithm Load Mutes FX Chain
#190248
    Hi, sorry for not getting back to you when you originally posted this question. This may be doable but I’m not sure if we’d be able to get to this for a while.
    Do you ever use the Direct I/O router? You may be able to take advantage of this for routing some of your inputs without using an FX Chain, and this could be a workaround.
    If you provide some more info about your setup I may be able to help with that.
