Home Forums Products Stompboxes Can’t adjust latency of insert in H90 Reply To: Can’t adjust latency of insert in H90
#190331
alpargatagazer
    Hey! Thanks a lot for the answer. I’ve doing some tests (all of this at insert mix 50% inverted):
    • No latency on the Boss. At sample 0 the volume is the lowest (but never is 0).
    • Same for the Ct5. However, when using the mode 2 or 3 and setting the mix of the pedal to 50% (with no loop recorded) and still in samples=0, the volume drops even more than when the mix is at 0%.
    • The problem comes with the CB it seems. At sample 0 the volume is very high. It then goes down. I found that at multiples of 130-140 samples the sound is more or less okay. It still sounds phasy though.
    I get what you mean with the parallel structure. I will take it into account, thanks!
