Home Forums Products Rackmount Eclipse mute via foot switch on pedal board Reply To: Eclipse mute via foot switch on pedal board
#190342
reese65
    Ok, will a standard TS mono footswitch work? I’ve read the manual but I have wired other effects units  to be muted via a footswitch using a 3pdt switch with led.
    If it needs to be a stereo switch with a 5 volt supply via resistor on my 9 volt power input, I will have to figure out how to transfer the 5volts from ring to tip and vice versa. Do you have any diagrams on how to wire that or possibly a footswitch from one of the manufacturers you would suggest?
