Home Forums Products Rackmount Eclipse mute via foot switch on pedal board Reply To: Eclipse mute via foot switch on pedal board
#190376
reese65
    Ok help me understand how to use a footswitch to bypass the eclipse when not in use on other songs from a pedalboard.
    if I use a footswitch that toggles continuity between tip / sleeve and ring / sleeve. Will this toggle the 5 volts between the tip and the sleeve depending on footswitch position?
    I know I would then have to calibrate and then use the bypass setup menus on the eclipse.
