Home Forums Products Rackmount Eclipse mute via foot switch on pedal board Reply To: Eclipse mute via foot switch on pedal board
#190403
reese65
    <span style=”font-size: inherit;”>I am just trying to be able to mute the eclipse when not in use. I just need a simple one button that can either mute or unmute that allows other rack units signal to pass through. On my pedalboard I have a combination stomp box switcher and switches that mute other rack mount devices. It’s the long box between the Wah pedal and the Boss Harmonist (which is no longer on the pedalboard) the 3 buttons on the left, one is pitch to mute the eventide, the cathedral mutes the lexicon pcm70, the DDLS is the dual delay and mutes both Roland SDE 3000’s simultaneously. They are all mono for now, but it’s my understanding per the manual that a stereo TRS is needed for the eclipse. If a standard mono cable can be used then I will be fine and I know how to setup calibrate and assign the function for the footswitch. I am just trying to find out if a standard mono footswitch will pork or if I need a stereo jack input to toggle the 5 volts the eclipse provides from the tip to the ring or can a standard mono jack work.
    </span>I am only using the eclipse for micro pitch function of + 9 cents for 1 channel and -9 cents for the second channel.
    all else fails I do have a foot pedal stomp box eventide harmonizer pitch factor that I can run to my line mixer.
