Home Forums Products Stompboxes H9 Volume too loud even Bypassed Reply To: H9 Volume too loud even Bypassed
#190623
    It sounds like you are doing something to increase the gain once the H9 is active, possibly related to the expression pedal.
    When connected to H9 Control, you should see a dropdown menu that shows “More” in the top right corner. Click this and check if the EXP pedal is set to control the input or output level.
