Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#190684
Talesmusic
    Some more ideas:
    – A way to adjust the expression taper so the expression pedal could effectively be used as a volume pedal. You can make it work as a volume pedal but the taper is not ideal.
    – The ability to select a different preset within the same algorithm for the Hot Switches.
    – Make Perform Mode the default state
