Home › Forums › Products › Rackmount › H9000 / RNBO public beta › Reply To: H9000 / RNBO public beta
I’m running into an issue with the RNBO export. The process builds and receives the binary, but doesn’t quite make it to the H9000 transfer. Is there a network or firewall setting that needs to be altered? I have tried both wi-fi and ethernet connections as well as both DHCP and manual IP assignments. Vsig and Emote both connect fine.
macOS 15.5
max 8.6.5 & max 9.0.7
rnbo v1.2.7-eventide.0
eventide H9000 1.0.4-beta3
H9000 FW: 2.2.11
This is the report from the Export Log:
Starting Code Generation
Generating Objects
Compiling Patcher
Printing CPP Code
Fetching platform description
Requesting cloud compile
Uploaded generated code and started cloud build (id: 59860)
Waiting for cloud build
Retrieving cloud build
Downloading compiled binary
Sending binary to target
connect EHOSTUNREACH 10.0.1.191:9000 – Local (10.0.1.127:62583)
