Home › Forums › Products › Stompboxes › Brian May Patch -H90 › Reply To: Brian May Patch -H90
I don’t know what everyone’s tried or heard before in Diatonic. Of course it’s important to select the matching Key & Scale, and the harmonies desired in Pitch A & Pitch B. Stick to single-note lines and simpler double-stops. But it’s equally important to simulate the multiple guitar overdubs.
Add up to several dozen milliseconds of delay time, with Delay A offset in time from Delay B (and also from your dry guitar). Balance between the harmony voices with Pitch Mix. Use an EXP pedal to slightly vary Pitch Mix to either side of center at A10+B10. That will a little greater emphasis on one or the other ‘overdubbed’ voice.
Here’s a quick example I tossed together that may give you a head start. Quant is OFF in Diatonic, for more forgiving string bends & wider vibrato. The Weedwacker instance in Series is optional. I just used it to push the midrange, and add some hair to the output.
