Home Forums Products Rackmount NEED HELP SETTING UP H9000/X8GEN2/LOGIC Reply To: NEED HELP SETTING UP H9000/X8GEN2/LOGIC
#191615
Jshermandds
    I have successfully set up an aggregate device in Logic and am connected with USB.  No network issues.  Emote is active, but:
    1.  I don’t get any input or output meter movement in Emote
    2.  I don’t get any sound or processing at all with the H9k.
    I understand that this must be a Logic routing error on my end, but I really need help please.  I have even gone as far as adding the Emote to the plugins on a track, but I just cannot seem to get any signal and processing on the Logic track from the H9k.  I did have the Emote input and output as USB 1-2 to USB 1-2.
    my objective is simple and I need guidance please:
    A.  I want to run H9k effects into a Logic pre-recorded track (Logic track – to H9K process – to Logic track via USB but be able to hear it from my Apollo X8 gen2) and
    B.  I would like to be able to record using H9k effects on the fly (at different times)(Avalon VST to Apollo X8 gen2 to Logic).
    please help.
