Home Forums Products Rackmount H9000 Gen2 DSP Upgrade Reply To: H9000 Gen2 DSP Upgrade
#192065
plikestechno
    Questions I have…
    Is it still ARM, just newer ARM, or a different type of DSP?
    Will you be able to combine DSPs?
    Will you be able to run more than 4 algos on one chain? Or two separate paths in one chain, like others have said?
    I don’t care about the same functions, just microseconds faster. It’s already plenty fast for my needs. As others have said, the old DSP barely gets flexed out as it is, it’s just currently a lot of bottlenecking in the programming (ie. can’t combine cores). If the bottlenecking is cause by lack of power then I look forward to actual improvements.
    An interesting development though, I wonder how it will affect things in the long run.
