Home › Forums › Products › Stompboxes › Wish list from users for future updates of the H90 › Reply To: Wish list from users for future updates of the H90
Hi, I’d like to please request that the inserts have the ability to be split into their respective send and return controls, similar to how it is done on the Helix/HX units.
For example, there could be an Insert 1 Send, an Insert 1 Return, Insert 2 Send, and Insert 2 Return.
This would allow for a lot more routing flexibility and full use of the hardware I/Os where sometimes it might not be possible with out switching to Dual Routing, but even that would be a bit more limited than this concept.
My use may be a little less traditional because I split my input signal to both the H90 and HX Stomp, have each in each other’s effects loop, and run independent stereo outs from each unit. I find this to already allow for some really creative routing, but it could be so much more. In my specific use with an HX Stomp, I would like to:
- Use a mono Send L block on the HX Stomp to “Insert 1 Return”, via In 3, on the H90, which is placed pre A.
- Then place “Insert 1 Send” via Out 3, placed post A, to the HX Stomp’s mono Return L block.
- Repeat the above using the Stomp’s Send R and Return R and the H90’s “Insert 2 Return” and “Insert 2 Send”.
Hope that makes sense. Thank you for considering. I love my H90!
