Home Forums Products Rackmount H9000 Gen2 DSP Upgrade Reply To: H9000 Gen2 DSP Upgrade
#192261
kims
    I’d rather you did more with the software instead of the hardware – 4 ARM CPU’s and still it can’t even do granular, what a joke in 2025.
    It’s like you don’t bother messing around with the software for too long, that often also has bug after bug
    It seems you are so lazy about programming, that you just pass it on to another producent, which as the owner of the expensive H9000, then have to pay extra several thousand dollars for, to use with H9000
    That was just some tough advice about the developments in the year 2025 that you are about to lose, if you don’t bother to keep up with VST, VSTI.
