Home Forums Products Rackmount MIDI Tap Tempo Control for Eclipse Reply To: MIDI Tap Tempo Control for Eclipse
#192375
Scoodva
    I have read the manual. I found that the CCs list is absolutely useless and irrelevant because any CC number can supposedly be assigned to any parameter, rendering the labels on page 45, which I have read over several times, meaningless. For example, when I assign the CC# of the button I am programming to 3 and then use the Capture function on the EXT setup, it says the source is MIDI Double, which it is not, it’s just CC# 3.
    My button on the console only sends one value. It does not send the value of 0 when depressing. I did program a second button to send 0 so I manually toggle between the two buttons just to see if anything changes and nothing so far.
    The H9000 is not good news. It’s $7k and the digital I/O does not operate at 192kHz which is what I use in the studio. My Bricasti can…
    I realize that this is a long discontinued piece of gear and that Eventide has no interest in further developing controller software/plug in control for the Eclipse. But it is such a great sounding effects unit, far superior to plugins. An updated version of the Eclipse would be great.
    Paul
