Home Forums Products Stompboxes Settings for a really choppy trem Reply To: Settings for a really choppy trem
#192571
    A couple things to try below:
    Harmadillo: Set everything to 0, Set X over to min or max value, Depth 100, set Shape to one of the pulse options. Once you have a sound you like start adjusting the other parameters to find some cool sounds.
    TremoloPan: Depth at max value, Shape set to square, Spread set to 0.
    Undulator: Intensity and Depth at max value and Shape set to square.
    You may have luck with Aggravate which has a great Pump control but there will always be a bit of distortion added.
