Home › Forums › Products › Stompboxes › Settings for a really choppy trem
- This topic has 2 replies, 3 voices, and was last updated 1 year ago by
brock.
October 14, 2025 at 3:57 pm #192569
I can’t quite get the H90 to do a really choppy, stuttering trem. The kind with complete silence between each repeat. Usually on other applications I just change it to square wave, increase the depth, and have the signal set to fully wet, but I can’t seem to accomplish that here (there doesn’t seem to be a mix or dry/wet knob…). Im trying it with a synth in the first slot and I can’t get the tremolo in the second slot to either be choppy enough, plus when I play a synth note it kind of rings out first and then the tremolo kicks in.
I’ve experimented with tremolo pan and Harmadillo. I can get sort of in the ballpark, but not really what I’m looking for. I also am not an expert with this thing so any help would be much appreciated. Could someone recommend the algo and what settings to use for some really hard chop?
October 14, 2025 at 5:26 pm #192571
A couple things to try below:
Harmadillo: Set everything to 0, Set X over to min or max value, Depth 100, set Shape to one of the pulse options. Once you have a sound you like start adjusting the other parameters to find some cool sounds.
TremoloPan: Depth at max value, Shape set to square, Spread set to 0.
Undulator: Intensity and Depth at max value and Shape set to square.
You may have luck with Aggravate which has a great Pump control but there will always be a bit of distortion added.
October 15, 2025 at 9:37 am #192578
All great recipes above. TremoloPan – Opto Type with Edge=100 might be a good starting point. Some algos have a Ramp Down LFO waveform, which can accentuate the attack. Actually, the Chop Machine section of UltraTap is a versatile choice for customized tremolo. And, depending on which synth you’re using, you may be able to add to the choppiness within the synth itself.
… Im trying it with a synth in the first slot and I can’t get the tremolo in the second slot to either be choppy enough, plus when I play a synth note it kind of rings out first and then the tremolo kicks in…
How are your Mix parameters dialed in? Try setting the Program & *Synth* Mix=100, and the depth of Preset B maxed out, as described above. You can dial them back from there for a little more unmodulated synth or dry.
