Home › Forums › Products › Stompboxes › TIME IN MICROPITCH PEDAL › Reply To: TIME IN MICROPITCH PEDAL
October 16, 2025 at 10:58 am
#192599
If the pedal is in Tap Time mode, the delay time will be in mS from 0-3 seconds.
If the pedal is in Tap Tempo mode, the delay time will be note divisions that are synced to the tap tempo.
If you look at the last page of the QRG that may help you understand how it works: https://cdn.eventideaudio.com/uploads/2021/10/MicroPitchDelay-QRG-Web.pdf
You can use the H90 Control app to adjust the pedal parameters and this will tell you the exact delay time values being set: https://www.eventideaudio.com/downloads/?product=H90+Control
Let me know if you have any questions.
