Home Forums Products Rackmount NEED HELP SETTING UP H9000/X8GEN2/LOGIC Reply To: NEED HELP SETTING UP H9000/X8GEN2/LOGIC
#193326
Dubvibe
    Hi, thanks for getting back to me.. I appreciate it.
    Yes, I wish to run the H9000 via USB, as an aggregate device with the UFX3 and no I don’t want TotalMix involved (it makes everything more complex I find).
    I have set up my aggregate device and can see signal hitting the in’s and out’s of emote but can’t hear anything. I think my problems are with stages 2 thru 5 as
    it seems to be a routing issue. Everything seems like it should be working but nothing comes out of the speakers.
    I tried plugging a guitar into audio input one and got a signal through emote and back to logic but again couldn’t hear anything.  I have Logic set to aggregated device for both
    input and output..is that correct? I used Audio Midi setup to create the aggregated device and have my RME interface set to handle audio in and out.. Is that correct?
    I use Logic’s utility I/O plugin to route signal to my outboard gear, I can’t see how the numbers the plugin shows relate to channels though.
    I suspect that the answer is simple but I’m not seeing it.
    Cheers
    Danny
