Home › Forums › Products › Rackmount › the connection to dsp 4 was lost › Reply To: the connection to dsp 4 was lost
are you using the Gen1 or Gen2 cards? Gen1 would need the 2.x, the Gen2 needs the 3.x firmware – the machine will not boot if you don’t have the appropriate level installed for each as described. In case you are on Gen2 and you get the message that the <span style=”font-size: inherit;”>DSP is lost the only thing I can add is that on my machine I had the issue that booting the machine would end in the machine not recognizing one DSP and showing it as „unassigned“ in the setup menu.</span>
Eventide Support yesterday hinted that it could be related to the WIFI stick that came with the unit. It seems like if it is plugged in while booting it is causing the unit to fail in recognizing some DSP, like in my case. I was just considering to send in the unit for repair but today I removed the Wifi stick and repeatedly booted the machine successfully. Strange stuff but for now it seemed to fix the issue. Hope that helps….
