Home › Forums › Products › Stompboxes › Update to H90 fails › Reply To: Update to H90 fails
December 19, 2025 at 7:51 am
#193936
You’ll need to get the H90 Pedal drive to show up on your computer for this to work. This may be an issue with your USB connection, or the pedal not booting into Recovery Mode correctly.
Do you see this on the H90 screen when you do the Recovery Mode button combo?
If so, then the pedal is booted into recovery mode and the issue is something else.
Can you try a different USB cable or connecting to a different computer?
