Home › Forums › Products › Rackmount › Feature request: “Save to H9000” should switch to the newly saved session › Reply To: Feature request: “Save to H9000” should switch to the newly saved session
#194029
    Sorry, I’m not sure if I follow your request. Are you updated to the latest version of Emote and H9000 firmware? Some improvements were made to this in the last few updates.
    When you select “Save to H9000”, it does create a new Session, and that becomes the currently loaded Session. For example, start with the 901 Reverb busses, select “Save To H9000”, and create a new Session name. You will now see that new Session in the Session browser, and the currently loaded Session title at the top of Emote and on the front panel are both updated to that new Session title.
    I can see how you mention when you save again and Emote prompts for the Session title, that will not always reflect what the currently loaded Session is.
    If the request is to fix the Session save dialog so it always is pre-populated with the current Session title, I will log that.
    If the request is something else, please provide more details.
