Home › Forums › Products › Stompboxes › H90 not routing dry signal in 4 cable mode › Reply To: H90 not routing dry signal in 4 cable mode
#194285
    Glad to hear you figured it out.
    I wouldn’t suggest factory resets if you are trying a new configuration and are having issues. We’ll be able to respond to your posts and help you troubleshoot issues before a factory reset is necessary.
    If you do want to reset your unit, make sure you back it up first (see #1): https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/h90-control/edit.html#parameters-edit-menu
